Old 10-20-2005   #1
quick2.4
1G driving issue
im new here an new to my dsm
its a 1990 eclipse fwd turbo
mods so far mbc, k&n filter , 2-1/2 turbo back exhaust with side dump
i devloped an issue with regular driving the car is spuddering an jerkey sometimes an if you listen to the exhaust while your driving it sounds like it has a mis and the idle is also up an down. oh i also have a boost leak now that im working on im just gona install a fmic with hard pipes an scrap the hoses
possable problems im thinking of is
1 vacuum leak
2 fuel filter
3 coil pack
4 plug wires
im just wondering if any of this sounds like any issue anyone may have had an fixed already
thanks Bryan
an any info is appreated
quick2.4 is offline   Reply With Quote
Old 10-20-2005   #2
1QUICK4
Crash Course Racing
1QUICK4's Avatar
Drives: in circles
Re: 1G driving issue
Check your plugs & wires, fix the boost leak, check your timing, and do a compression test to see if you burnt up a valve.
Old 10-20-2005   #3
quick2.4
also the car sat for 2 years before i got it so thats why i was thinking about the filter im gona change it any way when i get a chance too
Old 10-20-2005   #4
93sc
93sc's Avatar
Send a message via ICQ to 93sc
What kind of maintinace stuff did you do when you got the car?
93sc is offline   Reply With Quote
Old 10-20-2005   #5
quick2.4
change all fluids an plugs, pcv, air filter, altinator, optima yellow top
Old 10-20-2005   #6
93sc
93sc's Avatar
A couple other things after the above might include going through your vacume lines looking to make sure their hooked up, and then to see what kind of condition they might be in (ie cracked, brittle, leaking ect...), and while your doing your compression test take a look at your plugs to see how things are running.
Old 10-21-2005   #7
quick2.4
i alreadt put new plugs in an its not too rich or lean they look good
Old 10-21-2005   #8
Ok first of all, clean up your posting (shift key). I think you solved your own problem in your first post. Boost leaks will cause the symptoms that you are describing. Fix that and get back to us if the problem still persists.
Old 10-21-2005   #9
quick2.4
Ok thanks
Old 10-21-2005   #10
GVR-4579
also i just had a fuel pressure problem that made my car do something similar check your fuel pressure
Old 10-22-2005   #11
quick2.4
Ok I have a fuel pressure gauge but i have not hooked it up yet. what it the stock pressure supposed to be?
Old 10-22-2005   #12
GVR-4579
I dont know what it is on the talons and such i think 38 PSI the galants are different for some reason
Old 10-24-2005   #13
quick2.4
Ok thanks for the info
