Old 10-21-2005   #1
quick2.4
Ok How To Make A Data Logger Cable
i need to make a logger cable for my laptop an i havent been able to get anything to work im trying to make one but no luck yet any extra info is welcome
quick2.4 is offline   Reply With Quote
Old 10-21-2005   #2
Re: Ok How To Make A Data Logger Cable
www.pocketlogger.com
Old 10-21-2005   #3
slowbubblecar
Big Turbo Monster
slowbubblecar's Avatar
Drives: GTS and E55
you solder wires...
7/25/09
Old 10-21-2005   #4
quick2.4
Originally Posted by slowbubblecar
you solder wires...
WOW your so smart did u figure that out all by yourself ?
Old 10-21-2005   #5
slowbubblecar
Big Turbo Monster
Drives: GTS and E55
yep....I used to make them and didn't have problems when I did. You might as well just buy a cheap ebay one if you cant figure it out.
7/25/09
Old 10-21-2005   #6
GVR-4579
if you do a search on yahoo or something you will find the instructions. but you need a resistor dont remeber wich one, a diode, and a cable that attaches to the datalogger besides the obvious solder and soldering iorn
Old 10-22-2005   #7
quick2.4
wow maybe you should share the info then ! I have the diode , 10k resistor an the serial port an the cable im using with the connectors for the ALDL car side
but when i hook everything up it dosent do anything. An i have already tried swapping pin 2 an3 an that dosent work ? im using a palm pc program an i have mmcd and pnstein . Any extra info is helpful
Old 10-22-2005   #8
GVR-4579
where are you located you could compare it to mine if you want
Old 10-22-2005   #9
quick2.4
Im in MICH
Old 10-22-2005   #10
GVR-4579
Ok nevermind i am in minnesota sorry about that
Old 10-23-2005   #11
needthespeed69
I will have to look around and see if I can find a cable. I wasn't too hard to make but I cant remember exactly how I did it. I made it for a laptop though. I am not sure if the palm one would be different.
needthespeed69 is offline   Reply With Quote
Old 10-23-2005   #12
slowbubblecar
Big Turbo Monster
Drives: GTS and E55
^ was me above.
7/25/09
Old 10-24-2005   #13
quick2.4
That would be great because im using an laptop too
Old 10-27-2005   #14
LightningGSX
Hellbound
If the diagram was for a palm, and depending where you put the diode(what diode did you use anyway?) switching pins 2 and 3 might not work.
-Nulli Secundus-
Old 11-09-2005   #15
Jepherz
Send a message via AIM to Jepherz
Switching pins 2 and 3 is all you ever have to do when going from a PC to a Palm. Some palms may not work, so make sure you have a compatible model. Likewise, some laptops (older I think) have really picky serial ports and they won't pick up the signal. Since you are making a passive cable, this 'may' be a problem. If you still can't figure it out, contact me and I can ship you one for like $16. LMK, Jeff.
Jepherz is offline   Reply With Quote
