Old 11-17-2005   #1
' 92 AWD Timing parts (6 bolt)
hi, i have a '92 AWD (6 Bolt), need all front cover part #'s and prices.
t-belt, t-belt tensioner, balance shaft belt and tensioner, idler pulley, etc.
Pretty much everything that should be replaced when doing a t-belt for the first time in 100k miles. Also a crank pulley.
Thanks
Aaron
Old 11-18-2005   #2
DSMPARTSGURU
Keeper of the lost toys!
Re: ' 92 AWD Timing parts (6 bolt)
ALL PARTS are in stock!!!!
t/ belt $60.78
t belt tensioner $73.20
t/ belt pulleys $23.90 / 28.14
b/belt $23.22
b/ belt tensioner $23.38
crank pulley $101.90
thanks
chris
CHRIS
Wayzata Nissan
Old 11-21-2005   #3
can i get all the part numbers that i will need for that job, will i need front cover seals?
Old 11-22-2005   #4
DSMPARTSGURU
Im not sure if you will need them, you will have to inspect your car....
chris
CHRIS
Wayzata Nissan
