Old 01-08-2006   #1
ARP Moly Lube - where to buy
Where's a good place to get ARP Moly Lube around Minneapolis? Is there a generic moly lube that will work as a replacement?
Thanks in advance.
Old 01-08-2006   #2
EclipseGST
EclipseGST's Avatar
Drives: Short Bus
Re: ARP Moly Lube - where to buy
I know summit has it but thats the only place I can find any. One of the sponsor venders might be able to hook you up with some.
Originally Posted by shoutbox
Old 01-08-2006   #3
I should have a packet laying around somewhere.
Old 01-08-2006   #4
Sweet, if I swing by tomorrow do you think you can score me some?
Old 01-09-2006   #5
I have one waiting for you.
Old 01-09-2006   #6
ecoli, you are the shiznit! I'll swing by later.
Old 01-17-2006   #7
i would like to axe if this is a good head pre-lube. i'll be installing valves, cam, rockers, etc. should I use this ARP stuff or maybe a different more specific lube?
Old 01-17-2006   #8
tim
tim's Avatar
I dont think the ARP moly lube is meant for assembly lube. Go get a tube of actual assembly lube "white grease" from NAPA or CarQuest.
Old 01-17-2006   #9
No. ARP is more of a assembly lube. You use it with ARP bolts because that is what the torque values "supplied" are made with.
(sometimes when you get a torque spec it is assuming you are using arp moly lube, no lube at all (dry), 30W oil, etc).
There are lubes (like mentioned above) for pre-lubes. This shit would destroy your upper end if used in that form of an application.
Old 01-18-2006   #10
ok, i had some laying around from a while ago, probably too old to use anyway, but i might also have some regular assembly lube from back when i put my engine together. i'll use that or similar. thanks.
Old 04-11-2006   #11
Sorry to bring this back from the dead, but I need some sort of lube for 1 head stud. When I took the head off, one of the head bolts came entirely out, not the nut, te entire stud. So I need to put it back in but don't have any ARP lube around, so what can I use, and where can I get it? Thanks
Old 04-11-2006   #12
Pimpin Dsmstyle
Br0k3N
Pimpin Dsmstyle's Avatar
I might have some laying around. I'll check sometime when i have time.
- Josh L.P.
Old 04-11-2006   #13
I have a big ol bottle of the stuff(when I ordered it I didnt know it was that big) If you stop by my house after 12 tomorrow I can let you use some.
Old 04-11-2006   #14
Well I work in Shoreview, so maybe after work I could stop by and snag some. I work right off Hwy 96 and Lexington.
Old 04-11-2006   #15
Where do you work at? I live northeast of there. By County Road J and 49. Give me a call If you want to stop by. Cell- 651-492-5547
Old 04-12-2006   #16
slowbubblecar
Big Turbo Monster
slowbubblecar's Avatar
Drives: GTS and E55
You are going to use it on the side that goes into the block? I am pretty sure you aren't supposed to use it on that side. I thought the directions said to only use it on the side where the nut is and to clean the holes in the block out so there is no oil in there.
7/25/09
Old 04-12-2006   #17
Yea, the ARP Moly Lube goes on the washer, nut and threaded stud end that the nut goes on to. You don't put lube on the side that goes into the block. If anything, you would put loctite on the threads going into the block, but that isn't necessary.
Old 04-12-2006   #18
Studs go in the block dry, with dry holes.
ARP lube on the washer, bottom of nut, and the stud that sticks out.
Old 04-12-2006   #19
OK well I'm a dumbass then, i had put it on both sides before. But either way I guess I still need some for the nut side. I'll give you a call when I'm on my way out of work. I work at PaR Systems, right off Hwy96 and Lexington, and I get off at 3:30
Old 04-12-2006   #20
iceminion
iceminion's Avatar
Ok, from the ARP website, its ok to use oil in place of moly lube, you just need to tighten it differently....
I have a head that I need to bolt up to a block for a while and I have arp headstuds
unfortunately the washers are no where to be found? can I get some hard washers from ace? (same footprint as the nut)
and what is the foot poundage that I have to tighten them to? with 30w oil?
