Old 12-22-2005   #5
slowbubblecar
Big Turbo Monster
slowbubblecar's Avatar
Drives: GTS and E55
Re: Tranny Choices.
Originally Posted by niterydr
The 90's require shifter cable modifications, and the t-case switch. Switching out the shifter is also a good idea/required.
You don't need a different shifter. I think all you need to do is take a bracket for the linkage off the old tranny and swap it along with the t-case. If you found a 90 tranny, make sure to get the t-case and make sure all parts are on the tranny. You will need to swap some of them.
I wouldn't bother with the 2g tranny swap. You could get 700-800 for a used 2g awd tranny if it is in good shape. Used 1g ones go for 300-400 generally.
7/25/09
