Old 12-10-2007   #17
blageo23
AWD4G64
blageo23's Avatar
Re: having N00b problems.....
Yeah dude stop being a dickhead. are you sure your SAFC is wired up correctly/ setup correctly. DOUBLE CHECK THE CAS. and if you look at a manual you will notice that you dont line up the CAS with the "dot on the camshaft", you line up the dot on the camshaft sensor housing to the dot on the "plate"(the part that spins). Also like Sleepy said make sure that plate is on correctly(im the dickhead that put it on wrong cuz he was fighting with his bitchy ass girlfriend)! Make sure the MAFT is wired correctly...
