View Poll Results: Does Spaz like the rubber fist?
Yes, possibly multiple fists. 28 71.79%
No. 1 2.56%
Is hiding his fear of vagine by participating in these acts? 10 25.64%
Voters: 39. You may not vote on this poll
Old 02-03-2009   #11
Re: Does Spaz like the rubber fist?
And besides that, there's a slowly growing puddle of oil on the cardboard I park over, the source appearing to be where the head meets the block on the front left of the motor, so I've probably got a bad head gasket if not a cracked block now. And to top that off, the new clutch is slipping, because a couple assholes on here told me it was perfectly fine to boost on it during break-in as long as I didn't launch it.
Are you sure the leak isn't from a crack in the valve cover, the drain hole in the valve cover or spray from dipstick? All of which are common causes for oil over there.
Yes, you shouldn't boost, launch or shift quick on a new clutch if it's an organic disc. But if it wasn't/isn't adjusted right that is a more likely cause of slipping. Or if the rear main or tranny is leaking oil onto the disc. Or the clutch is just to weak for your power. Even if you aren't the nicest to a new clutch, they usually don't fail right away.
Shane@DBPerformance is offline
