Old 06-08-2011   #1
Re: Evo X upgrades
That's good! Hopefully it stays that way. Does the Weldon controller operate a dual voltage setup then?
Old 06-08-2011   #2
mlomker
*Resting In Peace*
mlomker's Avatar
Re: Evo X upgrades
Not quite, it's an interesting device. It uses some sort of pulse modulation to limit the current but it always operates at the same voltage. You use a pot to adjust the amount of current sent to the pump at idle and then you send voltage to a terminal to trip it into full current. They say it is a 0.5v drop vs alternator voltage at 20amps.
