Old 11-17-2014   #9
talonsway
Drives: 1995 eagle talon TSI
Re: Ricks-TURBO TALON
I had a 1g throttle body on my car but never had any issues with it. I had a 2g tps sensor on it sent to the .63v via dsmlink and just had a block off plate on the bottom so no other sensors. I had no issues other than what you'd expect with no idle motor as I had to keep my foot on the gas when it was warming up and had to blip the throttle when going to neutral but nothing crazy. Never messed with any throttle stops or anything like that, just bolt on and go
I think i might rock the 1g throttle body and a block off plate. The car is gonna be driven only in the summer so it shouldnt be a problem!
Would anyone be able to tell me sense im getting codes that are hinting that my MAF is bad or bad wiring ? And i want to go to SD. Would this be the right time to do that? or will it still cause problems even if i eliminate the MAF and go to SD. So basically switch to SD or buy another MAF?
talonsway is offline   Reply With Quote
