Old 06-27-2015   #101
Re: Troy's Evo
Was pretty badass watching you pull on those other bikes last night! Glad we could get a run in too Things borderline retarded lol
Old 06-27-2015   #102
MorningWood
Drives: Evo 8, 2014 Silverado
Re: Troy's Evo
Originally Posted by Mark Leasure View Post
Congratulations on the first couple of 9second passes!
http://www.youtube.com/watch?v=X9qs6m6zxQg&hd=1
Thanks again for getting that!
I haven't had that much fun in a long long time. I kind of lost perspective on how fast my car actually was. We'll have to do it again some time for sure!
MorningWood is offline   Reply With Quote
Old 06-27-2015   #103
Re: Troy's Evo
I said hi to Bryce and your roomy, but didn't meet you. Nice seeing the car in action.
Old 06-27-2015   #104
MorningWood
Re: Troy's Evo
It was a blast, too bad I didn't get some vids. I rarely let it stretch its legs on the street like that so I wasn't too prepared lol
Old 06-28-2015   #105
Re: Troy's Evo
Take it to the ass whooping thread and let us know how you did.
Old 06-28-2015   #106
MorningWood
Re: Troy's Evo
I don't have vids unfortunately just 2 against Josh's Evo. Brads gopro was facing the other way when we ran. Not sure if the other bikes I raced had them or not either, kind of a fail on my end, I even forgot tools :/ lol
Old 08-03-2015   #107
MorningWood
Re: Troy's Evo
Finally got on the dyno this year. Same set up as last year minus the Intake manifold. My friend let me know someone cancelled at DB so I was able to sneak in. It went fairly smoothly, minus some vacuum lines popping off even though I had them zip tied. The car was being difficult and wouldn't idle for shit most of the time, not sure why, but it's always kind of had a shitty idle. Boost was 40 psi dropping to ~33 psi.
Shootout Numbers:
20150803_134642 by Troy Akemann, on Flickr
Uncorrected:
20150803_134714 by Troy Akemann, on Flickr
I was pumped it made this much. I was expecting barely over 800 but this just blew my mind
We're so lucky to have such good tuners here in MN
Old 08-03-2015   #108
Re: Troy's Evo
Mother of god.
Shane has a way of exceeding peoples expectations
Old 08-03-2015   #109
bramagedained
bramagedained's Avatar
Drives: EVO IX SSL
Re: Troy's Evo
Wonder what it would look like with that overlaid from when the shortblock was in my car.
Old 08-03-2015   #110
Re: Troy's Evo
Yours spooled a little faster and had more power around 6000-7000, his looked like it would have better top end power, if he ran as high of boost as you were.
Old 08-03-2015   #111
Re: Troy's Evo
Nice numbers!!
Old 08-03-2015   #112
Re: Troy's Evo
Fuck that's awesome sauce!
Imagine if it held 40psi!! :fap:
Old 08-03-2015   #113
bramagedained
Drives: EVO IX SSL
Re: Troy's Evo
Shane settled it. Troy needs E98 and the boost cranked up so we can see how the same shortblock does with different setups.
Old 08-03-2015   #114
MorningWood
Re: Troy's Evo
Mother of god.
That he does, he did a damn good job!
Nice numbers!!
Thanks Brad, Might have to give me another shot at the bike
Shane was saying electronic boost should help that. It'd be interesting to see if we can still run close to the same timing up top with more boost
Haha, No e98 for me I don't think, i'm too nervous to try and push man boost like that, only way I might be able to touch your car if I go to a bigger turbo. Hopefully this little bit of lag and less torque will keep my trans together
Old 08-03-2015   #115
Re: Troy's Evo
6766? 6870? 7175? 7285?
Old 08-03-2015   #116
MorningWood
Re: Troy's Evo
I'd probably try the 6870 if they would make it in a V Band Exhaust housing. I called them when they released it, and they said they were planning on trying it out, whatever happened with that I guess i'm not too sure. I'm not sure if a bigger turbo would even help me at only 40 psi, this thing seems to be right in its sweet spot from 36-40
Old 08-03-2015   #117
Mark Leasure
Mark Leasure's Avatar
Re: Troy's Evo
Boss power! Are you still planning to go to the shootout?
www.maperformance.com
Old 08-03-2015   #118
bramagedained
Drives: EVO IX SSL
Re: Troy's Evo
Realtalk: Don't chase for more, until you're sure you can't do any better driving the setup you have.
Eventually, you'll get to the point where you strip teeth off of the gears in the trans like I did. And that sucks.
Old 08-04-2015   #119
MorningWood
Re: Troy's Evo
I wanted too, a couple friends I was going to go with ditched so I'll just put it on the agenda for next year
Yeah, I'm perfectly fine with what it has now. I have that other caged shell I could totally gut and throw this set up in if I get bored.
Old 08-04-2015   #120
Re: Troy's Evo
Is this still on the 6266? If so, that's crazy power out of a 62mm!!
