Old 04-20-2005   #9
TalonFiero
moonshine power
TalonFiero's Avatar
Drives: 08 Saab 9-7x Aero
Re: Will a 2G Tranny Mount to a 1G (6 bolt motor)
For those who are not following this thread correctly.
Brian has a 2g AWD eclipse that he is swapping a 6bolt motor into. Nothing in the drivetrain will need to be changed, only the starter plat and a 6 bolt flywheel will be needed.
Brian you will also need to do something about the counterweight on the 2g tranny shift arm as it will interfere with the lower radiator hose when routed to a six bolt water pipe. Most people cut them off.
Jim
