Old 03-29-2008   #1
dustinw
dustinw's Avatar
Drives: 96 Talon TSi AWD
injectors question
96 talon tsi awd, new engine, garrett t28r, evo manifold, apexi n1 exhaust,
its running lean and i think it might have stock injectors. any recommendations on what injector size to go with based on my turbo and setup?
no AFC is on the system yet. and its constantly running lean.
dustinw is offline   Reply With Quote
Old 03-29-2008   #2
Re: injectors question
How do you know you're running lean.
Instead of guessing on the injectors you should take them out and look at them to know what they are.
Old 03-29-2008   #3
dustinw
dustinw's Avatar
i hooked up an air/fuel gauge and its constantly sitting on lean unless i shift, then it goes optimal momentarily.
Old 03-29-2008   #4
EclipseGST
EclipseGST's Avatar
Drives: Short Bus
Was it a Wideband gauge?
Check injectors, what boost are you running?
Originally Posted by shoutbox
Old 03-29-2008   #5
What kind of air/fuel gauge?
Old 03-30-2008   #6
dustinw
dustinw's Avatar
glow-shift 3 gauge pod, oil pressure, boost, and a/f
Old 03-30-2008   #7
dustinw
dustinw's Avatar
was at autozone today, the guy working there came out and looked. he said the vacuum system is plumbed totally wrong.
the wastegate is hooked to the manual boost controller which is hooked to the BOV.
theres several 3 way splits and he said some of them are wrong.
i dont know jack about it though.
Old 03-30-2008   #8
MustGoFaster
MustGoFaster's Avatar
Drives: A big dirty V8
Ehh, you probably have stock injectors and a bad/dying O2 sensor. And from the sounds of it you bought a car that's been played with by somone that shouldn't have been playing. Not all bad, it can be fixed.
Old 03-30-2008   #9
twack
It was a auto get over it
twack's Avatar
wow someone at autozone was right about something... you see something new every day
Old 03-31-2008   #10
User Name
Hates blue couplers.
User Name's Avatar
Drives: White 1Gb TSi
^Yeah that's crazy, I would've never went to AutoZone for help, other than a battery test.
Good luck on the fix though. Check www.vfaq.com first before you ask questions around here, you might get your fingers bitten off.
I know I've seen tons of pics on how to hook the vac lines up.
ForSale:
90 OFH+Cooler/AN fittings
FIC 850
FP Turbo kit
Old 03-31-2008   #11
dustinw
dustinw's Avatar
i didnt go to auto zone for help with the car, the guy working there happened to be a dsm owner and enthusiest himself.
Old 03-31-2008   #12
brando
Drives: gutlass
where is this auto zone?
glad you got it figured out tho. but you should probably upgrade the injectors anyways and go with an afc
Old 03-31-2008   #13
dustinw
dustinw's Avatar
elk river
Old 03-31-2008   #14
Gravy
Who's this guy?
I don't know who that would be, i work the Pep Boys in CR, had a guy with a DSM stop in today and talked for a good while. May have to swing out there and visit the guy.
Old 04-01-2008   #15
dustinw
dustinw's Avatar
i have his name and phone number, i was gonna buy an safc from him
