Old 05-14-2008   #1
Capinoy123
Capinoy123's Avatar
Drives: A paint faded Red/pink/black 90 eclipse. Collector Plates!
Twin Disk question?
Why do twin disks squeak when you first put your car into 1st and start to engage the clutch? (from a full stop?) Just want to know so when people ask me, "why does your car squeak?" I can tell them. and not look like a fool who's car squeak's from when i first let the clutch pedal out. Thanks fellas!
Best E.T 10.5 @ 137 on 30 psi, E-85 and street tires! (never dyno'd)
Capinoy123 is offline   Reply With Quote
Old 05-14-2008   #2
brando
Drives: gutlass
Re: Twin Disk question?
how many miles are on the clutch?
Old 05-14-2008   #3
Because there's no marcel spring in the clutch discs, they're just material on metal. When you let out the clutch, there's no "spring" there to take up the tension, so it's a bit more direct. Single disc puck clutches have the same type of engagement and sound.
Besides that, if you can hear your clutch at all, your exhaust isn't loud enough.
Old 05-14-2008   #4
brando
Drives: gutlass
+1
Old 05-14-2008   #5
I can hear mine and I just have 3in d.p. back straight piped no muffler
Old 05-15-2008   #6
I would guess its the disk vibrating (just like a break pad in a caliper), the twin disks is the only clutch for a DSM I have heard that noise from. I have used solid hub 6 pucks(gAyCT) and sprung 6 pucks and full face sprung metal disks(South Bend clutches), and they did not make that noise.
Old 05-15-2008   #7
Steel on aluminum squeaks, the hub on a twin disk is aluminum with a steel plate sliding on it. I think that is part of it and is caused by the vibration. Mine doesn't really squeak any more as it got wore in.
Old 05-15-2008   #8
Capinoy123
Capinoy123's Avatar
thanks guys, thats what i thought. Its a brand new clutch i just installed two days ago. I'm just now used to all the new noises this clutch makes. Its a clutch masters twin disk 7.25. I love it!
Old 05-15-2008   #9
v8klla
v8klla's Avatar
QuarterMaster ;-)
Chris Carey, President
Modern Automotive Performance
P: 763-545-3800
E: chris@maperformance.com
