Old 05-24-2008   #1
mdost03
Sonic Champion!
Drives: VA STI
Anyone know where I can find replacements for these "plates"?
I don't actually know what these things are called, but after looking at the turbo, I am missing two. Could this be the source of my slow spool-up since it could be leaking exhaust gas out there instead of sealing up good against the hot-side housing? Anyone know where I can find replacement "plates" to put on there? It's a PTE 50 trim turbo and currently am hitting 20 psi at around 5500-6000 rpms.
Old 05-24-2008   #2
Re: Anyone know where I can find replacements for these "plates"?
Pte?
Old 05-24-2008   #3
^bingo.
Old 05-24-2008   #4
mdost03
Sonic Champion!
Drives: VA STI
Sent them an email just now. Didn't know if these plate things are universal or not. I'll probably call them monday also, thanks guys.
Old 05-25-2008   #5
THey make 2 diff kinds, ones that use 2 bolts so maybe 2 inches long and another kind that uses 3 bolts, basically semi-circle clamps that cover half the turbo.
Old 05-25-2008   #6
mdost03
Sonic Champion!
Drives: VA STI
Yeah, these ones are the 2 bolt ones. So do you think missing these plates would cause my extremely slow spool-up?
Old 05-25-2008   #7
brando
Drives: gutlass
that could be. but then again I'm no expert. it does seem like they are supposed to be there tho. did you have the turbo rebuilt by anyone recently?
Old 05-25-2008   #8
mdost03
Sonic Champion!
Drives: VA STI
Nope, this is what was on the car when I bought it.
Old 05-25-2008   #9
mdost03
Sonic Champion!
Drives: VA STI
OK, I pulled the turbo off a little bit ago and took a closer look at this. This is what I figured out (sorry about the crappy paint picture).
How it is suppose to be (suppose to have 2 plates total). Held on by 4 bolts (2 in the middle and 1 on each side)
How it is:
So somehow the plate broke in 2 spots. At least I have a better idea of how this turbo is put together now. Realized Memorial Day is tomorrow so I'll have to wait until tuesday to call up PTE and see if they would sell a plate separately (don't see why not).
Old 05-26-2008   #10
311evo
311evo's Avatar
hopefully this improves your spooling situation.
Old 05-27-2008   #11
AwdGSX13
AwdGSX13's Avatar
Drives: Cars
doubt thats the problem. Been like that since i bought the turbo. Check the shaft play..
-Matt
'94 Eagle Talon TSI AWD
'06 Acura TL
Old 05-27-2008   #12
mdost03
Sonic Champion!
Drives: VA STI
Barely any shaft-play on the turbo. Doesn't smoke or anything either.
Old 05-27-2008   #13
AwdGSX13
AwdGSX13's Avatar
Drives: Cars
hmm... id check everything for boost leaks ect. since dudeman took the trans back out.
-Matt
'06 Acura TL
Old 05-27-2008   #14
The plates to not seal anything. They hold the housings onto the center section. The housing has a flat spot machined into it and thats what seals the housing to the center section. Its not good they are missing so replace them for sure, but do a boost leak test, try a different boost controller, make sure there are no exhaust leaks before the turbo.
Old 05-27-2008   #15
And people wonder why I hype stock/stock-frame turbos so much.
Old 05-27-2008   #16
The T-2small has this type of connection on the exhaust housing....
Old 05-27-2008   #17
mdost03
Sonic Champion!
Drives: VA STI
Diesel Components Inc. have it, but I didn't make the drive to go grab it today. Me and AwdGSX13 were discussing the car today and figured we may have a boost leak around the intake mani since I have an abnormal idle. For now, I may just leave it as-is because apparently it doesn't seal up anything there like I thought and then track down where the leak is towards the intake mani.
Old 05-27-2008   #18
AwdGSX13
AwdGSX13's Avatar
Drives: Cars
how much did they want for the plates? i could probably spit on diesel components from my work. Maybe i can stop by and pick them up for ya
-Matt
'06 Acura TL
Old 05-27-2008   #19
mdost03
Sonic Champion!
Drives: VA STI
The guy didn't say a price, he just told me to bring in the turbo and he would find one that fit. He said he knew what I was talking about and that they had some.
Old 05-27-2008   #20
AwdGSX13
AwdGSX13's Avatar
Drives: Cars
oh ok, well i know the guy that owns diesel components so if you decide to go their for them let me know. maybe i can get you a better price.
-Matt
'06 Acura TL
