Old 06-06-2008   #1
bertrenolds5
bertrenolds5's Avatar
Drives: 91 eagle talon GST
torquing exhaust mani studs
Should I torque or hand tighten my exhaust mani studs? If I torque them, what should I torque them to?
Old 06-06-2008   #2
Re: torquing exhaust mani studs
You *should* torque them, but I think most of us just tighten them by hand.
Old 06-06-2008   #3
bertrenolds5
Any idea what to torque em too? I have a dial wrench.
Old 06-06-2008   #4
wants to be sideways...
123abc's Avatar
Drives: Loud cars
I would think it tells you in a repair manual.
I just tightened them to where I felt comfortable.
Originally Posted by Matt D.
Originally Posted by 93GSX5SD
Old 06-06-2008   #5
GsXtUrBo98
GsXtUrBo98's Avatar
Drives: 98 GSX, 04 is300
I think its like 56 but im got sure
98 GSX (built)
03 BBY EVO dd
GSX 463awhp 363awtq on DB!
Old 06-06-2008   #6
bertrenolds5
I'll look through my chiltons but I don't think it's in there.
Old 06-06-2008   #7
Look harder, it should be in there
Old 06-06-2008   #8
bertrenolds5
Nothing, I've got 18-22ftlb for the nuts and 40ftlb for the 4 bolts for the mani to turbine housing, but nothing for the studs. I might try checking the torque on the studs that are on the car right now and got with that.
I would think 56ftlb's would be way to much for a steel bolt in an aluminum head.
Old 06-06-2008   #9
The studs into the head? Just turn them until the center part with no threads reaches the head and gets snug, don't overtighten because they'll strip out.
That method has worked for me in the past.
Old 06-06-2008   #10
mdost03
Sonic Champion!
Drives: VA STI
Just hand-tighten them and once it gets snug, give it a 1/4-1/2 turn to where you feel comfortable. Use some thread locker on it too.
Old 06-06-2008   #11
What? I use anti-seize on them, not thread locker, otherwise they're a bitch to get out. Oh and RTV the bottom center one otherwise it may leak oil.
Old 06-06-2008   #12
bertrenolds5
Snuged them all up and used anti-seize on all the studs and put red rtv on the center lower stud. Thanks everyone for helping me, glad I dident torque them down to 56ftlb gsxturbo98.
Old 06-06-2008   #13
GsXtUrBo98
GsXtUrBo98's Avatar
Sorry, I was confused as to what bolts/studs you where talking about...then when you were more clear I wasn't on.
98 GSX (built)
03 BBY EVO dd
Old 06-07-2008   #14
RED RTV is the absolute worst shittiest RTV ever, says the Permatex brand rep. Shoulda gone with Ultra Black... And whats so bad about putting lock-tite on the studs? don't want them to back out... which has happened to me.
Old 06-07-2008   #15
mdost03
Sonic Champion!
Drives: VA STI
Exactly, I have had studs move around and tighten up more as I've tightened up the nuts onto them so I put a little dab of thread-locker on them and let it sit for about 5-10 min and then they are good to go. I've also taken studs out that have thread-locker on them and they aren't much harder than if they didn't have anything on there.
Old 06-08-2008   #16
bertrenolds5
I believe the thread locker would just burn away, my studs don't move at all. I tighten them all up a tad and used anti-sieze, silver not copper but hopefully I wil be fine, I don't wanna mess with it anymore.
Does anyone know anything about the rtv on the center stud? Why do you need to put it on, is it some kind of joke or something?
Old 06-08-2008   #17
thread it in a bit then the last few threads throw some RTV on it
Old 06-09-2008   #18
HiImBrian
HiImBrian's Avatar
Drives: the girls crazy
I didn't use any rtv on my exhaust mani. Just make sure it's o2 sensor safe otherwise your o2 might go bad soon.
I also use thread lock on just about all my bolts and they are no harder to get off.
pics or gtfo
Old 06-09-2008   #19
I thought the bottom center stud goes through an oil passage in the head, and it may leak if you don't use the RTV on it.
Old 06-09-2008   #20
HiImBrian
HiImBrian's Avatar
^never had that problem, nor have I ever had oil come draining out when the main is off.
pics or gtfo
