Old 09-28-2008   #1
twack
It was a auto get over it
twack's Avatar
1g 6 bolt awd auto to manual swap parts
seeing if anyone had all the parts fr the auto to manual swap i need everything from pedals to tranny. let me know what you got and how much you want for it
Old 09-28-2008   #2
Re: 1g 6 bolt awd auto to manual swap parts
90 or 91+ would help
I have a 90 tranny that is all taken apart sell it for 100
Old 09-28-2008   #3
EclipseGST
EclipseGST's Avatar
Drives: Short Bus
You're going to need a different rear end and t-case as well Travis.
Originally Posted by shoutbox
Old 09-28-2008   #4
Febo
Manic Narcissistic
Febo's Avatar
Drives: IS300
I can confirm this. Your gunna need:
Trans
Cables
Cable brackets and C clips
Firewall Cable rubber grommet thingy
Shifter Assy
Pedal Assy, make sure its out of an AWD, I noticed there is a difference in pedal assy's
Master Cylnder, 1.8l one will work. I have one that needs a rebuild, shoot offer
Clutch line
Abs bracket with hole if you have abs
Rubber hose from hard line to slave cylinder
Slave cylinder
Clutch
Flywheel
Transfer
Rear Diff
Manual ECU
Then make sure to connect the two black wires on your 12 pin tranny connector
You will also need a small spring to permanantly keep your key in the unlock position. Or you will need a manual ignition.
You will also need to retain your original stop light switch, and find the wiring diagram to make your reverse lights work. I havent gotten that far yet. Its annoying.
I think thats everything that you will need. So plan accordingly.
Old 09-29-2008   #5
GnArKiLl
GnArKiLl's Avatar
^^^ you dont need to switch ignitions.. or do the spring thing you are talking about. mine works just fine w/o all that
Old 09-29-2008   #6
Febo
Manic Narcissistic
Febo's Avatar
Drives: IS300
... How did you pull that one off because there is a cable that runs from your shifter to your ignition that keeps you from pulling the key out unless your in park. And that little lock thingy is just a little lever that is pushed up or let to fall down by said cable, and if it falls down your key is stuck in the ignition. I learned this from first hand experience after removing the cable and then putting the key in and I couldnt get it out.
Old 09-29-2008   #7
twack
twack's Avatar
This is for a 92 im kinda hoping someone has all the parts or a good chunk of them or im probalby going to stay auto and look for another auto tranny. I dont have time to travel up and down to the cities trying to find each and every part, ya know
Old 09-29-2008   #8
Febo
Manic Narcissistic
Febo's Avatar
Drives: IS300
I can get you a master cyl, shifter assy, cables and center console and have them shipped if you would like. I also have a pedal assy that might work, it needs to be tightened up. But its out of a 1.8l. I could throw that in for dirt cheap.
Old 10-03-2008   #9
c4uldr0n
Drives: '92 Eagle Talon TSi AWD, 2.3L Stroker
I have a TRE stage 3 transmission, transfer case, and rear end, flywheel, clutch... etc. If you want to purchase my whole chassis (engine removed), you are more than welcome to purchase it all for a steal, please contact me. -Korri 218 390 9410
c4uldr0n is offline   Reply With Quote
Old 10-03-2008   #10
u pull it in east beathel has a 94 awd with the 4 bolt in it still and the t.c. is still there also is the tranny but it needs a new bellhouing
Old 10-05-2008   #11
At-Least-It's-An-Evo
At-Least-It's-White-Again
At-Least-It's-An-Evo's Avatar
Drives: 98 iVTEC
i have a buncha stuff, you might wanna get at me before i trash it tomorrow........
'04 Honda Ricer: stock
Old 10-05-2008   #12
twack
twack's Avatar
Im in north carolina for a couple weeks doing job training so ill get back to everyone when i get back thanks
Old 10-05-2008   #13
CarPsyco84
CarPsyco84's Avatar
I have a 4 bolt pumpkin, 5spd LSD one...
-When in doubt, Moar RPM.
Old 10-05-2008   #14
95talonracer
Finally Tuned...
95talonracer's Avatar
Drives: Spyder GSX
I have a shifter assembly for a 91+ that ill ship to you.
Amsoil Dealer
