Old 03-19-2009   #1
Need a fitting turned/cut flat.
Need to do this:
http://www.dsmtuners.com/forums/arti...bb-turbos.html
Old 03-19-2009   #2
Re: Need a fitting turned/cut flat.
$10 bucks, or I might have a left over PTE restrictor, I will look tonight.
Old 03-19-2009   #3
s1ngletracker
s1ngletracker's Avatar
Drives: A BMW
Yeah, why not just use another type of restrictor?
Style's automotive engineer
Old 03-20-2009   #4
Just get the FP red colored filter? I know it costs a bit but it also restricts/filters...
Or if you're going ball bearing get a fitting that has the pinhole opening for $12.
Old 03-20-2009   #5
It has been found that the orifice on the FP restrictors are not all what they advertise. Also the orifice is too big on FPs restrictor and i would get one of the those flanges with a restrictor in it, but my turbo doesn't have bolt holes for it.
The other option is to feed from the head.
Old 03-20-2009   #6
Rosey has a lathe at work.
Old 03-20-2009   #7
MustGoFaster
MustGoFaster's Avatar
Drives: A big dirty V8
At work we typically just drill and tap. Thread in a set screw and drill any size orifice you want. But drilling set screws can be a bit of a PITA since they are hardened.
Old 03-20-2009   #8
in hot it done thx. kyle at map
Old 03-21-2009   #9
munchgsx
munchgsx's Avatar
Drives: 2004 Corvette M6 F45
^Dude mabye not so much vicadin
