Old 03-29-2009   #1
ESchwanz
ESchwanz's Avatar
Drives: 97 GSX
Any Ideas on how to plug this properly.
The plug Chris put in to this oil port is leaking badly!! is there an OEM one or does any one have a better quick fix? Thanks!
ESchwanz is offline   Reply With Quote
Old 03-29-2009   #2
Re: Any Ideas on how to plug this properly.
Don't 2G's come stock with the correct plug?
Old 03-29-2009   #3
I just have a bolt in there with a crush washer. WHy the heck are there so many washers under there?
You could probably try adding a little RTV or liquid teflon, might help it seal better.
Old 03-29-2009   #4
ESchwanz
ESchwanz's Avatar
Drives: 97 GSX
Dunno have to ask Chris...
Old 03-29-2009   #5
x-pride
x-pride's Avatar
If the bolt is to long cut it down to the right length and use a crush copper washer. That is how I plug mine. If you don't want to cut it down get the bolt from 90 to 94 NA 2.0 engine.
Old 03-29-2009   #6
And make sure your bolt has the right thread, that one is suspect.
Old 03-29-2009   #7
ESchwanz
ESchwanz's Avatar
Drives: 97 GSX
What is the correct thread & size???
Old 03-29-2009   #8
95talonracer
Finally Tuned...
95talonracer's Avatar
Drives: Spyder GSX
WTF?? Find out the correct thread size and pitch and get a flush allen set screw with some sealant/lock tight and you are good and it looks good too!!
Amsoil Dealer
Old 03-29-2009   #9
I might have a spare one I could let you have. Just some hex head bolt that looks a lot like what you have in there, but cut shorter so it fits without stacking 6 washers on it.
Old 03-30-2009   #10
munchgsx
munchgsx's Avatar
Drives: 2004 Corvette M6 F45
Either a set screw or do like the NA's have. I think is a 12mmx1.25 but not to long.
Old 03-30-2009   #11
AwdGSX13
AwdGSX13's Avatar
Drives: Cars
it probably wouldnt leak if their wasnt so many damn washers on their.
-Matt
'94 Eagle Talon TSI AWD
'06 Acura TL
Old 03-31-2009   #12
That is sick, save that pic.
I have a shortened bolt, with crush washers on it.
Old 03-31-2009   #13
4g63tcrazy
is Nashty
4g63tcrazy's Avatar
Drives: Cyborg from Japan
2g heads have the bolt you'd need if you wanted to go that route.
-1990 Mitsubishi Cyborg 4WD-
Old 04-01-2009   #14
lucasoil4u
Drives: talon tsi evo 3 25psi
yikes i love how the washers dont line up at all!
lucasoil4u is offline   Reply With Quote
Old 04-01-2009   #15
GREASEMONKEY
GREASEMONKEY's Avatar
Moon Lander Champion!
Drives: 92 TSi
Just get the plug / bolt out of a NA 4G63 Head. Problem solved.
