Old 08-24-2009   #1
redline
redline's Avatar
Drives: GSX
GT35R questions?
So the car I picked up has the punishment gt35r kit on it and I have been having some smoking under hard boost. I put a check vavle in the pcv system ( also has a catch can ), routed the valve cover breather through a catch can back into the intake and did a full tune up. The car is running on pump/meth with a 75/25 mix and I am seeing around 11.2-11.3 on the wideband at 25 lbs of boost with only .5-.7 knock. Car pulls great, but the smoke is starting to bother me. There is very minor shaft play and all the blades are clean and are do not look like they have come into contact with the housing. Tonight I noticed that there is a little bit of oil seeping out between the center section and the turbine housing. I am not sure if the previous owner put the oil restrictor on with the turbo, but I am seeing north of 100 psi of oil pressure at wide open throttle ( built shortblock and new oil pump ).
I know the center section isn't rebuildable on the 35R, but are there seals that can be replaced? Any suggestions?
redline is offline   Reply With Quote
