Old 07-22-2010   #1
Brandito93
Brandito93's Avatar
Drives: 1989 Nissan 240SX RB20
Send a message via Skype™ to Brandito93
Upper Intercooler Piping
My upper intercooler piping keeps popping off. I have no idea why. I just got a brand new coupler and it continues to do so. Any thing that might help or if you want more info let me know. I'll do the best that I can to explain it. I'll show a pic of where it is popping off when I get out to my car next.
Brandito93 is offline   Reply With Quote
Old 07-22-2010   #2
Re: Upper Intercooler Piping
Try using T-bolt clamps to hold it on?
Old 07-22-2010   #3
Brandito93
Brandito93's Avatar
Here is the picture
Old 07-22-2010   #4
bertrenolds5
bertrenolds5's Avatar
Drives: 91 eagle talon GST
I used hose clamps on my IC piping, just don't over tighten them. Maybe the IC pipe coupler is to big? Hose clamp is to big and doesn't get tight enough?
Old 07-22-2010   #5
Make sure both surfaces are fairly clean of any oils and such, if all else fails you might want to have a couple of beads welded onto that part so the couple does not slip off. A lot of factors could be causing your problem. From the picture it looks like it is not centered and there is constant tension towards your throttle body.
Old 07-22-2010   #6
Brandito93
Brandito93's Avatar
I'm pretty sure it's the picture it's pretty centered, (the couplers are just turned). But thanks.
Old 07-22-2010   #7
Constant_Project21
Constant_Project21's Avatar
Drives: E36
Your problem is those shitty spectre couplers, they're made out of a plasticy rubber type stuff, and when it gets hot, it stretches and they pop off. Spend the extra money and get some nice ones from MAP.
Old 07-23-2010   #8
Spikesoftail
Spikesoftail's Avatar
Drives: 96 Talon Tsi AWD Auto
+1 get some good couplers
Spikesoftail is offline   Reply With Quote
Old 07-23-2010   #9
GG_9_SE
E85=Win
GG_9_SE's Avatar
Drives: Evo 9 SE
hey brandon Im pretty sure your UICP doesnt have a bead on the end off it. and yea that spectre coupler is junk. any filter/coupler from oriellys is usually junky.
341hp/344tq E-85 FTW
Shane Tune@ DB
Old 07-24-2010   #10
CarPsyco84
CarPsyco84's Avatar
Rule #1, pipe ends need beads or any coupler with any clamp will blow it off.
Rule #2, T bolts work 10x better, last longer, and will give you less head aches, maybe not necessary if under 20psi.
Rule #3, what the coupler is made out of is important, specially on problem couplers... nice silicone couplers are still sticky when hot, rubber and junky ones expand, and get slippery and will slip off pipes.
-When in doubt, Moar RPM.
