Old 06-11-2011   #1
GsXtUrBo98
GsXtUrBo98's Avatar
Drives: 98 GSX, 04 is300
How many T's can you make in a vacum line?
I have a boost a pump and already have all the vacum line ports in use.. I have my boost controller T'ed off the BOV line but was wondering if I could get a piece that looks like + and run my boost a pump off of it aswell?
98 GSX (built)
03 BBY EVO dd
GSX 463awhp 363awtq on DB!
Old 06-11-2011   #2
stikx
Mr -
Re: How many T's can you make in a vacum line?
I think you want to have a dedicated line for the bov.
Old 06-11-2011   #3
GsXtUrBo98
GsXtUrBo98's Avatar
Kinda hard to do this when you have no vacum lines.
98 GSX (built)
03 BBY EVO dd
Old 06-11-2011   #4
^Then T into your line again.
Or buy a vacuum block.
Old 06-11-2011   #5
cmspaz
Walls need hugs too
cmspaz's Avatar
Yeah, don't tee into the BOV line for a boost controller, the pressure drop when the controller valve opens can screw with normal operation.
Tee off the FPR line for the sensor like you would for a boost gauge, and give the MBC its own line as well. Not like you actually need any of that emissions crap hooked up anyway.
Originally Posted by Trogdor
Old 06-11-2011   #6
GsXtUrBo98
GsXtUrBo98's Avatar
Boost guage is t into fpr line.
98 GSX (built)
03 BBY EVO dd
Old 06-11-2011   #7
cmspaz
Walls need hugs too
cmspaz's Avatar
Then tee off the line for the boost gauge inside the cabin?
Less mess in the engine bay...
Old 06-12-2011   #8
Get yourself a vacuum manifold, it'll make finding a vacuum source a lot less painful and it'll be cleaner.
http://www.maperformance.com/vibrant...lack-2691.html
Old 06-12-2011   #9
GsXtUrBo98
GsXtUrBo98's Avatar
I like this idea! Thanks!
98 GSX (built)
03 BBY EVO dd
Old 06-12-2011   #10
I said the same thing!
Old 06-12-2011   #11
GsXtUrBo98
GsXtUrBo98's Avatar
Ok sorry, thanks aaron
98 GSX (built)
03 BBY EVO dd
Old 06-12-2011   #12
95talonracer
Finally Tuned...
95talonracer's Avatar
Drives: Spyder GSX
Am I wrong or isn't your boost controller supposed to be connected before the throttle body like off the fitting from the turbo if equipped?
Amsoil Dealer
Old 06-12-2011   #13
OMFGeofffff
OMFGeofffff's Avatar
Drives: '90 Talon Tsi AWD
It's ideal to have it tapped in as close to the turbo as possible.
OMFGeofffff is offline   Reply With Quote
Old 06-12-2011   #14
GsXtUrBo98
GsXtUrBo98's Avatar
My turbo does not have a nipple off of it for the boost gauge
98 GSX (built)
03 BBY EVO dd
Old 06-12-2011   #15
Ive seen it tapped and sealed into a UICP after the turbo. Just simply drilling a hole in your UICP, and putting a barbed nipple and some sealant/JB to keep things from leaking.
Old 06-12-2011   #16
95talonracer
Finally Tuned...
Drives: Spyder GSX
x2
Amsoil Dealer
Old 06-12-2011   #17
Just make sure the BAP sensor is not on a vac line with an electronic boost controller, if you have a "standard" manual boost controller put it in line with what ever sees manifold pressure and you are good to go.
Its a dsm, put it in the crank case or water jacket and it might work just fine.
