Old 02-14-2013   #1
4seasons69
4seasons69's Avatar
How many miles before getting a tune?
Alrighty this is my first brand new engine. What I'm wondering is those of you who have broken in new engines how many miles did you put on it before you got a good tune and started having fun with the car?
The break in procedure that map gave says after 500 miles it should be ready for normal driving. Then it says I can switch to synthetic oil at 1500 miles.
So would I be good to go at 500 miles to get a tune and crank the boost up or should I wait till 1500 when I can switch to synthetic oil? What do you guys do with your engines? Thanks!
Old 02-14-2013   #2
EclipseGST
EclipseGST's Avatar
Drives: Short Bus
Re: How many miles before getting a tune?
I think we put 100 miles at most on Vassil's car before we took it to Shane.
Originally Posted by shoutbox
Old 02-14-2013   #3
Trogdor
Trogdor's Avatar
Drives: people crazy
Per Ron, when talking about my car.
-Don't be afraid to get on it.
-Use regular oil for the first tank of gas
- Change the oil, inspect the oil, refill using regular oil
- Run for 1000 miles using regular oil, then tune and change the oil with regular again
- Run for 3000 miles, then change back to synthetic
*Using regular because synthetic is too viscous, and doesn't allow the rings to rub enough on new pistons*
Trogdor is offline   Reply With Quote
Old 02-14-2013   #4
You should be afraid to get on it, if you don't already have a tune for your exact setup. The last thing you want is detonation on a new motor that hasn't has time to seat the rings yet.
Old 02-14-2013   #5
4seasons69
4seasons69's Avatar
Hmmm does he do a lot of street driving? There seems to be a lot of controversy on how to break in an engine. I have heard a lot of people say break it in how you're going to drive it. I'm shooting at least close to a similar power level as him so idk how important mileage is to higher hp engines
That's good info! As for the oil I have enough amsoil break in oil for the first 1500 miles
Old 02-14-2013   #6
4seasons69
4seasons69's Avatar
This is true. This is also kind of why im asking how long I should go before I get a tune because I want it tuned as soon as possible
Old 02-14-2013   #7
EclipseGST
EclipseGST's Avatar
Drives: Short Bus
Did street driving before switching to all slicks... He is also on E98. A lot less chance for detonation.
Old 02-14-2013   #8
Trogdor
Trogdor's Avatar
It might be a good idea to have Shane or Ron give your car a break in tune. Low boost, but still correct timing, FTA ratios, etc. That way to don't blow it up. Then break it in for like 1000 miles, and retune it.
Shane brings up a good point of clarification. My car is tuned, just not fully. So, I can get on it a little.
Old 02-14-2013   #9
4seasons69
4seasons69's Avatar
Gotcha yeah l will be on e85
That is a good idea but the problem with that is low boost on my car with my wastegate setup and a gt42 is like 36psi lol. So i want to get it broken in enough with the gt42 then switch to a pte 6766 and get it tuned
Old 02-14-2013   #10
You don't need to boost it to break it in. NA cars don't have boost and they break-in great. You want to pull some really high vacuum as much as possible to help with seating and vary your RPMs and loads.
Old 02-14-2013   #11
4seasons69
4seasons69's Avatar
This is a good point. How high should I bring the rpms? Red Line is set at 9500 and when we were done on the dyno you said not to bring it above 7k until I had the voltage drop fixed which I'm hoping I should have fixed
Old 02-14-2013   #12
Amsoil recommends using their break-in oil for 1,000 miles at the maximum. We used it for PlanoEvo's last build and honestly the rings did not seat well with it; we're using Supertech conventional this time around.
Old 02-14-2013   #13
4seasons69
4seasons69's Avatar
Amsoil recommends using their break-in oil for 1,000 miles at the maximum. We used it for PlanoEvo's last build and honestly the rings did not seat well with it; we're using Supertech this time around.
Hmmm my block is a map stage two and that was what map recommended. But that's good to know. I'll probably run that for 1k then switch to a regular oil for 500 miles before I go to synthetic
Old 02-14-2013   #14
EclipseGST
EclipseGST's Avatar
Drives: Short Bus
This!
All I've ever used and works great. Walmart! You change the oil early enough so it doesnt actually get a chance to break down.
Old 02-14-2013   #15
So are both of his. If you follow Amsoil's recommendations (like we did last time), use their break-in oil for 1k miles, then switch to their synthetic. This time around we're doing 1k miles of conventional then switching to synthetic.
Old 02-14-2013   #16
4seasons69
4seasons69's Avatar
Well I already have the amsoil so maybe I'll just run that for 500 then switch to the super tech conventional. Map recommended waiting until 1500 to switch to synthetic so ill probably try that this time around.
What weight Supertech do you use? Just a straight 30 like the amsoil or something different?
Old 02-14-2013   #17
I'd drive it like a normal car for 500 miles, then bring it to Shane, and let 'er rip. There's no need to do long extensive mild break-ins, the rings seat in the first 20-30 miles. I've always had phenomenal ring seal with this on every engine I've built.
Old 02-14-2013   #18
I just use Castrol straight 30 for the first 20 miles, Castrol 10W-40 to 100 miles, and change the oil again with 10W-40 at 500. I switch to synthetic at 1000 miles.
Old 02-14-2013   #19
10W-30, then at 1k miles he'll switch to 10W-40 synthetic (maybe experiment with 20W-50 in the hot summer months).
Once he's on synthetic he'll be dyno-tuned. We'd honestly probably only worry about a 500 mile break-in but we want to make sure the segmented Kevlar clutch disc gets properly broken in before beating on it too badly.
Old 02-14-2013   #20
4seasons69
4seasons69's Avatar
Okay thanks for the info guys! Map recommends changing the oil at 50 miles then 500 miles. So maybe ill run the break in oil for the first 20-50 miles then change it then run the rest of it that I have until somewhere between 100 and 250 miles then change it again and switch to a conventional for 1,000 to 1500 miles then switch to synthetic.
And I'll get her tuned at like 500 miles
