Old 07-21-2014   #1
Timing belt job on a 3S, any advice?
I'm looking to do a T-belt job on a '92 stealth soon, any advice?
Any bolts that get RTV'd?
Thanks
Old 07-21-2014   #2
Re: Timing belt job on a 3S, any advice?
Advice? Pay Swanny.
Old 07-21-2014   #3
dsmreck
dsmreck's Avatar
Drives: 98 gsx
Andre used to have a 3000gt I'm sure as built as his was he did a few timing belt jobs
Old 07-21-2014   #4
Sohc, Dohc, Turbo? They can be intensive, budget a lot of time and then budget some more.
Turbo DOHC tips:
Motor mount comes off in a particular order, otherwise good luck getting it out (driver side front). Also ensure you pull the motor mount and then the lower timing belt cover; otherwise you'll break the cover most likely. Track where the bolts go as they are all different lengths.
Crank pulley is probably separated, ensure it isn't before reassembly
You can put the accessory belt on and tighten the a/c pulley from below the car; makes it easier.
Power steering pump doesn't have to come off if you have the proper tools, but the idler/tension pulley does.
Go slow, have fun, ensure all 4 cam gears align and the motor is at TDC when you install.
Old 07-21-2014   #5
turbo motor sir.
Thanks for the help, not looking forward to it.
Old 07-21-2014   #6
It's not that bad. I have done a lot of them.
Old 07-22-2014   #7
Yeah it really isn't to bad at all; once you get over lining up 4 cams and the crank pulley; and working in a space to where even a monkey would be cramped
I've done worse as well. Just take your time Aaron, you'll be fine.
Old 07-22-2014   #8
What do you line the cam gears up to?
Old 07-22-2014   #9
There are marks on the valve covers.
Old 07-22-2014   #10
Not the head like a DSM then?
Old 07-23-2014   #11
twisted954
Possible Head Trauma
twisted954's Avatar
Drives: after suspension
http://www.youtube.com/watch?v=Il0uuJXXW_w
Not the best video, but not the worst and the motor mount is explained pretty well
Faster than pushing...
twisted954 is offline   Reply With Quote
Old 07-23-2014   #12
Thanks. Hopefully I'll be tackling this friday.
