Old 07-14-2005   #1
Enes
Enes's Avatar
Intake Cam tapping?
Where should i take my HKS Cam to get tapped for the CAS bolt.
HKS suposedly don't come tapped unfortunately ;( otherwise i'd have it installed now and running.
Or also what size is it?
-E
Old 07-14-2005   #2
Re: Intake Cam tapping?
I have had Motors by Gosh and the St. Louis Park NAPA do it before. Mike at QPR might be capable of doing it will all his equipment. I usually just take the bolt from the CAS to the machine shop with the cam.
Old 07-14-2005   #3
Nash
Nash's Avatar
I had mine done at the St. Louis Park Napa also.
Old 07-15-2005   #4
Enes
Enes's Avatar
The one on Lyndale?
3610 Lyndale Ave S
Minneapolis, MN 55409
Tel: (612) 827-2561
or
7400 West 27th Street
Minneapolis, MN 55426
Tel: (952) 925-0188
or
1842 Main Street
Hopkins, MN 55343
Tel: (952) 938-3517
Old 07-15-2005   #5
If it just needs to be tapped, we can do that here, give us a call tommorrow E man, or swing by before 6 and we'll take care of it.
Old 07-15-2005   #6
Enes
Enes's Avatar
it does need to be drilled even more..
Old 07-15-2005   #7
We can still probably do it. Just bring by the bolt and cam and we'll beable to figure it out (if we can or can't) real quickly.
Old 07-15-2005   #8
Onefast99gsx
It's pretty easy. My brother whom is a machinist did mine. Drilled it in a lathe and tapped it out manually. If you know anyone who has a lathe, you're set. All we did was wrap mine with this plastic mesh sheathing material they use for shipping. That way the lobes and the cam cap surfaces wouldn't get damaged.
Old 07-15-2005   #9
Yeah, only problem is our lathe is super tiny (9" diameter by 20" long work area).
Old 07-15-2005   #10
Onefast99gsx
Josh- we didn't need the large work area. Can you place items further back into the chuck, if you know what i mean? Our chuck we had on was probalby only 10-12" diameter but that didn't matter nor did the size of the work area. We only had about 1+" actually sticking out of the chuck. The rest was back in further. Just used a dial indicator for straightness dialin and drilled away.
Old 07-15-2005   #11
A cam would fit, but we don't have a live center, so no dice, sorry enes.
Old 07-15-2005   #12
slowbubblecar
Big Turbo Monster
slowbubblecar's Avatar
Drives: GTS and E55
Napa in st louis park is unlisted. If you are going west on 394 from 94, you would get of on loisiana. Then you take a right just before the post office and it is there. I forgot the name of the road. Let me know if you need the number. I got it from them once but don't have my cell here now.
James
7/25/09
Old 07-16-2005   #13
The SLP napa machine shop is located off louisiana and 27th (I believe). The phone number is 952-926-0347. I am pretty happy with his work. We were having compression issues and a possible warped head. He was going to mill it and did a tressure test on the head. Found 6 bent vavles and 3 bad guides on a head that ran. I will probly bring him more in the future. Quick turn around also.
