Old 08-09-2005   #1
PSI2HI
Custom 1G Setup Pics
Did something a little diff you usually dont see on DSM's as in most of the DSM crowd is if it dont bolt on i dont wanna bother w/ it. On the base tune it seems to be working out pretty well. Only made a few quick pulls on the dyno so far to get a rough tune as we ran out of time. So far on base timing 24 psi it made 484whp on a 3rd gear pull maxing out the 650's. Gonna be back on the dyno shortly after some new injectors. Only downfall is its a stock rod bottom end, doh!
Nick
SLS
Old 08-09-2005   #2
stikx
Mr -
Re: Custom 1G Setup Pics
nice! hey i was up in Fargo picking a Srt-4 for my brother wanted to stop by but i guess you guys dont open saturday because i called and only got the answering machine. Keep up the good work
Old 08-09-2005   #3
Ummm yeah. I would hate to be on the right hand side of you when the fucker takes off. I am sure it sounds pretty damn crazy. Weird setup, but cool too.
Old 08-09-2005   #4
PSI2HI
Yeah we're not open weekends as we're usually @ a race or show most of the time.
Old 08-09-2005   #5
illz
what is the point of that nonsense?
Old 08-09-2005   #6
Thats cool!
Old 08-09-2005   #7
PSI2HI
Typical DSMer comment right there!! Go back and play w/ your 16G.
Old 08-09-2005   #8
Illz whats your fucking problem, I think its cool that someone did something out of the ordinary, even if it doesn't have any power gains over a conventional setup in the end who cares.
Old 08-09-2005   #9
PSI2HI
Either way a manifold had to be built to accept the T3/T4 and i personaly like top mounts for the ease of working on them.
Old 08-09-2005   #10
Onefast99gsx
Being the turbine housing is that close to the hood, doesn't the hood get hotter than a bitch? Just wondering. That's the only thing that came across my mind when i checked the pics out.
Old 08-09-2005   #11
PSI2HI
nah, its perfectly fine. It's not as close as it may look.
Old 08-09-2005   #12
Enes
Enes's Avatar
um.. look at it this way...
1. WHAT back preasure on exhaust??! NONE
2. holy freaken short route piping!!! from turbo right into the FMIC..
-E
Old 08-09-2005   #13
91nbtsi
Send a message via AIM to 91nbtsi Send a message via MSN to 91nbtsi
It is a sweet setup. Just think if you got an AEM on there and ditched that stupid chipped ECU and AFC/VPC BS
10.806@133.15--1991 Talon
91nbtsi is offline   Reply With Quote
Old 08-09-2005   #14
illz
i don't have a "fucking problem", I'm wondering what the point of doing something bass-akwards is, when to the casual observer, it offers no gains and creates headaches. Additional heat killing alternators (if not necessitating a move of the alternator mounting to begin with), no place for the PS pump, limited room for a proper intake, a bunch of spare room on the left side now occupied by a big exhaust pipe running through your engine bay instead of out the bottom, etc.
I'm not allowed to ask a question and comment on it seeming nonsensical? Do you understand the meaning of the word "nonsense"?
1) having no intelligible meaning
4) of little or no importance or usefulness
Good lord.
Old 08-09-2005   #15
illz
there you go, that'd be a real answer, not "typical dsmer go play with your 16g"
with a top-mounted turbine, wouldn't that place the heads of your mounting bolts underneath?
Old 08-09-2005   #16
PSI2HI
Sure wouldn't. If you look @ the pics you can see it all clearly. The car doesn't run power stereringf nor AC nor dsid it have it befroe this setup. Everything clears the alternator, we have an intake that clears for it, etc..
Old 08-09-2005   #17
Actually there will be less heat on the alternator. There is usually a big DP running right next to it. Most drag cars don't use a PS pump either, so no biggie there. Intake? Cut a hole in the fender well. Why would you want spare room? It isn't doing anything, so why not use it?
The heat on the hood is a valid point. For a drag car it will be fine though. Other than that I kind of like the setup!
Old 08-09-2005   #18
91nbtsi
It is a full garrett turbo, hence the bolts thread into the manifold.
How is there additional heat to kill alternators? The hot side of the turbo and the exhaust(which the downpipe usually goes through right next to the alternator) is far away from the alternator. It is obviously for more of a race application.
Old 08-09-2005   #19
illz
thanks for real answers!
Old 08-09-2005   #20
Onefast99gsx
While you were at it, you should have turned it 90* more and made it stick out of the hood. That'd be cool. HEHE
Oh look at that shiny Magnus. Looks like mine.
