Go Back   MitsuStyle > Hosted Support Forums > Primo Performance
Old 03-06-2010   #13
mx3twinturbo
mx3twinturbo's Avatar
Drives: StarQuests>>>>>>
Re: Powder Coating Pricing
Normal powder coating processes will effectively make the metal more brittle because of the high temperature. The wheel will still be rigid, but it will not be able to withstand forces like it originally did. There are low temp powders that cure at around 375 degrees that are meant to be used for wheels and other parts that see stress.
As far as this goes,( there is a debate but most metallurgy finds this to be untrue)
To weaken or change the metals structure, you would have to heat it much higher and much longer to do anything to it, also when you get into tempering and such, the way it cools down is also a huge part.
So yes this is untrue, (in our case anyway,)
Thanks,
Jesse
1987 Conquest- 2.1 project started...
1986 Dodge D-50- S.C. truck 2.6 turbo swap started
1992 Mazda Mx-3- Rear mount twins in progress
1989 Suburban- Project for too Long!!!
"Just Remember, I HATE Drama"
mx3twinturbo is offline   Reply With Quote
