Old 03-26-2010   #461
Re: Evo X upgrades
Originally Posted by mlomker View Post
I went with a head from MAP. It'll be similar to the Cosworth. +1mm valves, Cossie dual springs, and their porting. They are going to clearance the MX1s so that'll save Shane a little bit of hassle on the reinstall.
What head are you exactly buying? Are they working over a stock head for you or something?
Old 03-26-2010   #462
mlomker
*Resting In Peace*
mlomker's Avatar
Re: Evo X upgrades
Yeah, they are ordering a new Mitsu core for me.
Old 03-27-2010   #463
mlomker
*Resting In Peace*
mlomker's Avatar
Re: Evo X upgrades
Ran to Dad's and did an oil change on the car that he's loaning me. I think I'll look for a set of hub caps for it.
Old 03-27-2010   #464
LingLing
AznKraut
LingLing's Avatar
Re: Evo X upgrades
I think a a set of black 17" RPF1's are the way to go.
What kind of power gains are you expecting to see from the cams and head work?
Old 03-27-2010   #465
Re: Evo X upgrades
Stealies are where it's at.
Old 03-27-2010   #466
mlomker
*Resting In Peace*
mlomker's Avatar
Re: Evo X upgrades
I'm changing a lot of stuff at once so I'll never know what the cams and head work did on their own (excepting the power gains above the stock rev limiter).
The dyno charts that I've seen have only shown modest gains from porting. Just about everything has been PPC now so the cumulative effect should certainly add some power. My main goal with the head is 9k rpms. I know for a fact that rpms will add power as long as the turbo is still breathing...evidence has shown the FP Red is still pulling at 8k so I have no reason to believe that the BBX will be out of breath before 9k.
There are a number of 1sts in this build so some questions won't be answered until Shane straps it down on the dyno.
Old 03-27-2010   #467
LingLing
AznKraut
LingLing's Avatar
Re: Evo X upgrades
Nice! I'm excited to see what this ends up at. You're gonna be going on the rollers at Boost For Boobies, right?
Old 03-29-2010   #468
v8klla
v8klla's Avatar
Re: Evo X upgrades
We plan to have the head done around April 15th, that doesn't leave much time for Shane to get the car back together and tuned, but we sure hope to see it at B4B!
Chris Carey, President
Modern Automotive Performance
P: 763-545-3800
E: chris@maperformance.com
Old 03-29-2010   #469
Re: Evo X upgrades
Hey if you decide to drag it you'll be able to rev it out in 4th no problemo!
Old 03-29-2010   #470
Murlo26
Murlo26's Avatar
Drives: 17 Honda Accord
Re: Evo X upgrades
Yup, 9k will do that for sure
ETS with their setup which is similar to lomkers, different brands and the addition of engine bearings, and they take theirs up to 10k rpms
I think he could do 9500 even honestly, but i doubt he will be making power up there, who knows
I would do enough to get 4th in the quarter and only go more if it kept making power.
Old 03-29-2010   #471
mlomker
*Resting In Peace*
mlomker's Avatar
Re: Evo X upgrades
I think he could do 9500 even honestly, but i doubt he will be making power up there, who knows.
We will play it by ear on the dyno. If by some miracle it was still pulling at 9k then we can up it for a pull. The motor really should be good until the springs give out and I'm going with Cosworth dual springs this time...given the price they better be the shiznit.
Old 03-29-2010   #472
mlomker
*Resting In Peace*
mlomker's Avatar
Re: Evo X upgrades
No. It'll get run at MAP whenever the build is complete but I'm sure Shane will need a good two weeks once he gets the head. After assembly the motor has to be broken in, then tuned. That's why the setback was unfortunate--there's still quite a bit of work after the cams are in.
These builds are endless, aren't they? I need to get rubber and the Volks on, set the ride height/corner balance, alignment, new brake system installed, fix the suction line in the tank, install gauges, install splitter/canards/wing, clean up vacuum lines, do a wire tuck to show off the Primo valve cover, install Ralliart tail lights, and maybe replace the trunk plastic that I scratched the piss out of.
I might even wash the f-ing thing if I can squeeze that in. lol.
Old 03-29-2010   #473
Murlo26
Murlo26's Avatar
Re: Evo X upgrades
You did brakes too, man you really did everything at once, lol.
Just get the damn thing running and enjoy for a bit first You need to love the evo a bit, by driving it that is.
Old 03-29-2010   #474
mlomker
*Resting In Peace*
mlomker's Avatar
Re: Evo X upgrades
I have pads and stainless lines here...plan to get Girodisc rotors later.
I would expect to burn up the stock setup by the end of the Summer. I want to learn how to do brakes on my own so I'll find someone to work with me on it when the time comes.
Old 03-29-2010   #475
Murlo26
Murlo26's Avatar
Re: Evo X upgrades
Yea i want to do brakes too, i am going to get a few more tools, stuff needing for taking my rims off so i can clean the brakes too. I need a nice torque wrench for sure. And then i need some bigger rachets etc.
Let me know when you plan on doing them i want to learn
Old 03-30-2010   #476
Re: Evo X upgrades
Ruh roh! Modding the 'beater' secondary car has started....classic!
Old 03-30-2010   #477
Murlo26
Murlo26's Avatar
Re: Evo X upgrades
LOL, that is one thing I am afraid of for when I get my second car.
Old 03-30-2010   #478
mlomker
*Resting In Peace*
mlomker's Avatar
Re: Evo X upgrades
Dad had a woman back into the car right before I borrowed it -- she cracked the hubcap and added another dent to the wheel well. He just let it slide but I would have at least had her buy a new set of hubcaps.
Old 03-30-2010   #479
Re: Evo X upgrades
Hahaha the first time I read through that I thought it said "Dad had a woman in the back of the car..."
Old 03-30-2010   #480
mlomker
*Resting In Peace*
mlomker's Avatar
Re: Evo X upgrades
haha. We be impressing the ladies in this ride.
