Old 11-19-2009   #11
Re: Black Friday sales!
Originally Posted by viridionplague View Post
another thing with the led's, they are darker compaired to lcd, but give much truer colors. they give better colors because the led's can be turned on or off creating much much more contrast.
led's also use about 40% less electricity than lcd's
another thing with the lcd's, is that if you have a bright spot, mostly white, it tends to be so bright it washes out surrounding colors
Again, as Tom and I have both stated, you still have an LCD. One is lit by a cold cathode fluorescent light, the other uses LEDs. Either way it's the same LCD panel. The LEDs are not turning on or off, it's still up to the LCD to block out light to make the screen look black.
